Configure broadcast, unknown unicast, and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
View the bandwidth limiter configuration:Switch:1>#show interfaces gigabitethernet rate-limit all
Port Rate(PPS) Limit
PORT TYPE RATE ENABLED/DISABLED
1/1 MULTICAST 0 DISABLED
1/1 BROADCAST 30 ENABLED
1/1 UNKNOWN-UC 0 DISABLED
1/2 MULTICAST 0 DISABLED
1/2 BROADCAST 33 ENABLED
1/2 UNKNOWN-UC 0 DISABLED
1/3 MULTICAST 0 DISABLED
1/3 BROADCAST 60 ENABLED
1/3 UNKNOWN-UC 0 DISABLED
The following table defines parameters for the rate-limit command.
Variable |
Value |
<1-65535> |
Specifies the bandwidth limit for broadcast, unknown unicast, and multicast traffic, in packets per second (pps). |
port {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
